I just need someone to confirm what i think i already know. Is the pressure sensor on the back of the engine block near the distributer on the passenger side??
There is also a special socket that makes it much easier to get it out & in.
Just so you know though, I picked up this socket when I swapped mine out and it worked great for getting the old one out but the bore diameter inside the socket wasn't big enough for the new unit.
Luckily I was working at a machine shop at the time with a lathe and we just milled a little bit of material out of the inside to get it to fit!
