Horn
Old Aug 20, 2009 | 11:12 AM
Ram15002ndGen's Avatar
Ram15002ndGen
Originally Posted by Miami_Son
That's just sad. Well, at least I'm helpful.
Why sad, because you have spent too much time here? That's because you busted up your leg dude. Nothing wrong with being helpful.
Originally Posted by 95MaroonMonster
ok, ill try to more of a post *****
spewing useless crap on the forum
Oh no, what have I done!
Old Aug 20, 2009 | 10:31 PM
Keegan's Avatar
Keegan
Its not the relay, I swapped a few different ones in there.
Likely the ground... the horns worked fine when I tested them right off the battery, so it must be the ground.
Thanks guys!
Old Aug 20, 2009 | 10:41 PM
95MaroonMonster's Avatar
95MaroonMonster
you created a monster
Old Aug 21, 2009 | 02:16 AM
Laramie1997's Avatar
Laramie1997
Thanks guys!
Just another thing: The stock horns are just merely electric motors. They can and will just quit working with out warning. Usually they start to sound weak before they die, but they can still just lock and quit.
Old Aug 22, 2009 | 02:07 AM
willstruck's Avatar
willstruck
When I bought my truck, I hit the horn button, and nothing. I replaced the fuse, and it just blew right away. Then, after being on here, I read that since my cruise control didn't work, and my airbag light was on, plus the horn problem, it was my clockspring. I spent fifty bucks on it the other day, I hope that fixes it...
Old Aug 22, 2009 | 10:15 AM
iwhitne's Avatar
iwhitne
I installed N ir horn from a semi connected to a 7 gallon air tank.. works great and I have less than $50 in it
Old Aug 22, 2009 | 12:04 PM
Keegan's Avatar
Keegan
Yeah I have a set of air horns hooked up in my car, I'll probably get some for the truck too, but I'd like to have the stock horns working as well.
