Fog light mod
#101
on
i didn't get snippy, i was starting to think i was retarded or something because i couldn't wrap my mind around what was being said.
as far as the h1 bulbs go, that is what i have in my off road lights and they are 100 watts each. then the fog lights are oem 896 bulbs in the factory fogs and 55 watt bulbs in the aftermarket fogs.
one of these days i'm going to get the same bulbs that jasonw has because i already have new wire laid and all i will need to do is swap the bulbs without fear of melting the inferior factory wires.
if you haven't seen the headlight relay DIY then you should check it out https://dodgeforum.com/forum/2nd-gen...-write-up.html
i can't remember if you have the single bulb or dual, but if you have dual then you'll have to keep in mind that the 9007 and 9004 bulbs have the wires swapped on the plugs when you start to wire up the relays. that is if you decide that you want to run your headlights on relays.
oh and Laramie, thanks.
#102
Just thought I'd mention that I've been running my fogs with the mod for a couple weeks now, and its still workin like a top, no melted wires, no burnt truck, etc. Seems to be a safe electrical mod to me. I figured I'd say somethin just in case anyone is worried about any ill effects or
#103
on
i've been running mine since 8-21-09 with all four fog lights hooked up the same as my wiring diagram and they're fine too. i run just headlights if its about to get dark, but as soon as it gets completely dark, the fog lights come on.
#104
ha I'm just the opposite. ANY time the truck is on I have the parks on, then If it's just startin to get dark, or snowin or somethin, I run the foglights, then pull the headlights on when it's dark. Then the rollbar lights
#109
Hey
Hey so u own a 97 ram factory foglight button on the dash next to od button can u take pics where the factory foglight harness that plugs into the foglight button ive been tryin to find the harness for mine mines wired for foglights from the front bumper to the harness that goes to the connector nd from therr the 15 amp fuse and both relays but next to the o/d button therr was a block off plate ive got a factory foglight switch commin from ebay and its same yr switch for my truck but cant figure for the life of me where to plug it into or where thst harness is
#110
