Fog Lamp Problems
Old Aug 21, 2009 | 06:38 PM
truegent81's Avatar
truegent81
Default Fog Lamp Problems
how are yall doing? im brand new to this site, i used to drive a ford but recently bought a 2001 dodge ram. i'm pretty excited about it and of course when buying vehicles, we want it to be done our way so i've come across some minor issues. first, the fog lamps didnt work. i replaced the fuse, and put two NEW bulbs in. i turn on the lamps and only one lights up. i went to auto zone because i wanted to test the current to the "dead" side but they didn't have anything. can someone help me out on this please? it looks like crap with one burnt out and i would like to get this taken care of soon. thanks again. also, i don't have a shop so i only have limited basic tools living in an apartment.
down the road i will tackle the ball joints (just had new u joints put on) and how to fix the dang front cup holder. dang thing is broke...any cheap (not trashy) ways to fix this as well? this is my first 4wd truck and i'm pumped because thats what i have always wanted
Old Aug 21, 2009 | 07:13 PM
oldspartan's Avatar
oldspartan
I had this happen once and it was a rusty socket that was killing the ground to taht side. Also check the wiring to the socket, could be
simple bad wire.
Old Aug 21, 2009 | 07:25 PM
truegent81's Avatar
truegent81
if it was a bad wire, wouldnt i just replace the whole fog lamp harness? but heck i havent found a replacement harness either. i hear dodge doesnt like to "give up" their parts to autozone, napa, etc. i mean the wire looks good visibly...will check
i'm gonn go check the wiring real quick while its still light out
thanks so far
Old Aug 21, 2009 | 07:30 PM
oldspartan's Avatar
oldspartan
while you're at it you might look a all the contacts in the lamp and make sure there is good contact there. Years ago while I was working in a truck stop this rust in the lights was not uncommon.
Old Aug 21, 2009 | 07:43 PM
truegent81's Avatar
truegent81
yeah, i went out there and followed the harness to all the connections and it seemed fine. i wiggled the connections and still nothing. im thinking maybe that connection in the socket (fog lamp pigtail) is jacked up. is there a device i can use to test the current going to the connector? if i can do that, then i'll know that the connection is jacked and to order a new pigtail.
Old Aug 21, 2009 | 07:57 PM
oldspartan's Avatar
oldspartan
A simple 12 volt test light will do. Put the probe on the light against the contact in the socket and the end of the wire in contact with ground like the truck frame or some solid metal part of the front bumper support.
Old Aug 21, 2009 | 08:14 PM
oldspartan's Avatar
oldspartan
If you don't get the test light on you could then see about checking on the backside if possible. My guess would be rust or dirt that is keeping the ground side of the circuit from completing.
