ECU has no calibration
Subscribe
Aug 29, 2009 | 11:55 PM
  #21
We have a fuel filter?????????? I thought we didn't have fuel filters on our trucks. I never saw anything on the driverside of the engine bay other than brake booster/master and such. I will have to check that out tomorrow. So when I was referring to the PCM as the ECM I was misquoting its nomenclature but we got the drift I hope.lol.
Reply 0
Aug 30, 2009 | 12:09 AM
  #22
Well that's the thing, he plugged his ECM in BUT he retuned the ECM to spec of my truck and it still pinged like crazy. It most definitely isn't vin locked though since he has used it on multiple 2nd gen dodges..
Reply 0
Aug 30, 2009 | 12:14 AM
  #23
he didnt plug into the port under your dash? the OBD II port.
Reply 0
Aug 30, 2009 | 01:24 AM
  #24
Quote: he didnt plug into the port under your dash? the OBD II port.
He did plug it into the OBD port.
Reply 0
Aug 30, 2009 | 01:40 AM
  #25
oh ok I thought you meant he plugged into the ECM itself
Reply 0
Aug 30, 2009 | 05:13 AM
  #26
I still want to know what causes pinging in my engine. And if I do get a superchips and it actually works how do I know it won't still ping with that? I thought the number 1 reason for pinging in these trucks was the blown plenum plate? I've got the Hughes on there so it shouldn't be an issue right? All I know is he said it's starving for fuel.
Reply 0
Aug 30, 2009 | 05:35 AM
  #27
Okay, I muddled through about half of this thread. If the plenum isn't leaking, (just because you have done the hughes upgrade doesn't mean it still wont leak) and you still have pinging or predet, consider this: What is octane?
All octane is, is a fuel additive to control ignition time for gas itself. When you advance the timing (which, I presume that's basically what happens with that tune) your octane needs go up. You could try on your next fuel up, putting like a 91-94 octane in and see what happens.
Reply 0
Aug 30, 2009 | 12:01 PM
  #28
Quote: Okay, I muddled through about half of this thread. If the plenum isn't leaking, (just because you have done the hughes upgrade doesn't mean it still wont leak) and you still have pinging or predet, consider this: What is octane?
I only put 91 octane in because of the pinging. So I take it there isn't much I can do accept for buy octane boosters since 91 is the highest we have around here. Dammit I'm starting to doubt my dodge
Reply 0
Aug 30, 2009 | 02:22 PM
  #29
Quote: We have a fuel filter?????????? I thought we didn't have fuel filters on our trucks. I never saw anything on the driverside of the engine bay other than brake booster/master and such. I will have to check that out tomorrow. So when I was referring to the PCM as the ECM I was misquoting its nomenclature but we got the drift I hope.lol.
You know what? I quoted the wrong stuff, my bad, I was totally wrong there. Diesels have a fuel filter and an accelerator pedal position sensor, gassers do not. Well, we do, but it's intrgrated into the regulator and not serviceable. The Service Manual doesn't designate diesel or gas very well in the electrical components listings. I was dead-dog tired last night posting that, my apologies.
I believe the gassers do have an ECM and a PCM, the ECM IIRC sits behind the PCM. I know I recall an old thread discussing ECM vs PCM. Unfortunately, you or I won't be able to search for it as the stupid forum filter drops anything with 3 letters or less, making most sensor related searches worthless. Sorry I couldn't be more help.
I've never heard of a hyptertech programmer with adjustable parameters like your describing, Terranova. I'm amazed they haven't marketed that, they could have made a killing before SCT.
Reply 0
Aug 30, 2009 | 02:27 PM
  #30
Quote: I still want to know what causes pinging in my engine. And if I do get a superchips and it actually works how do I know it won't still ping with that? I thought the number 1 reason for pinging in these trucks was the blown plenum plate? I've got the Hughes on there so it shouldn't be an issue right? All I know is he said it's starving for fuel.
Did you torque down the plate correctly? I saw that you removed the fuel rails from the keg. do you think you might have a vacuum leak? A vac leak will let extra air in that is not monitored by the map sensor to adjust fuel trims and will lean out the a/f charge. You might try spraying a little soapy water on the tops of the injector bosses and see if you get any bubbling while running the engine. That could indicate a vac leak due to a bad injector o-ring.
Reply 0
