Check engine light, but no code
Old Aug 30, 2009 | 05:16 PM
Philipn's Avatar
Philipn
Default Check engine light, video of code
I have some trouble with my RAM 2500 -95 360. The check engine light goes on maybe once a week but when turn off the truck and restart, the light is off. I have tried the "key dance", but no code. The truck runs perfect. Does anyone have an idea of this problem?
Last edited by Philipn; Aug 31, 2009 at 09:52 AM. Reason: I did do the keydance wrong...
Old Aug 30, 2009 | 05:40 PM
jasonw's Avatar
jasonw
Site Moderator
Make sure you have the key dance correct...
Turn the key from "ON" (not "START") to "OFF" three times, the last time leaving it in the "ON" position. The CEL should blink your codes to you. Write down the blinks.
Many auto parts stores will check the code for free. If the CEL is on, especially if its repeatedly, there pretty much has to be a code.
Old Aug 30, 2009 | 06:27 PM
Laramie1997's Avatar
Laramie1997
His wont do that. He will have to count how many times the CEL light flashes. I would rather go to a parts store and have them run the code, or buy a scanner for about $90.
Old Aug 30, 2009 | 08:32 PM
004x41500's Avatar
004x41500
he has to buy an OBD1 scaner, and your light goes off because the code that caused it to come on was a "soft" code, meaning it clears itself when the key is turned off. but there will still be a code present in the computers memory, the MIL/SES light will NOT be lit, until the specific parameters of that perticular code are met again.
Also check in the pending codes as well, sometime the codes go back into a pending state, after the MIL/SES light is turned off.
Im not entirely sure where you can buy an OBD1 scan tool at, but if you know someone with a SNAP-ON Modis they usually have what you need to scan a pre 96/97 with OBD1.
Old Aug 31, 2009 | 05:23 AM
Philipn's Avatar
Philipn
I do the keydance right, I'm shore. There are not many Dodge specialist in Sweden but I found one that might help me. Thanks!
Old Aug 31, 2009 | 09:49 AM
Philipn's Avatar
Philipn
Sorry, i did do the keydance wrong. Her is a video of the code. If I'm not wrong again, it's code 12 and 21?
http://www.youtube.com/watch?v=BDfQJJT9Z7w
Old Aug 31, 2009 | 10:29 AM
Aubrey's Avatar
Aubrey
It looks like 12 and 21.
