cel came on yesterday
Old Sep 16, 2009 | 06:54 PM
wjxavier's Avatar
wjxavier
while you have the pan off you should inspect the wire thats on the bottom of the valve body to make sure it hasn't rubbed through the insulation, its not common but if it does then you will have an rpm surge in overdrive.
mine kind of does this, but only does it slightly when i'm going down hill and coasting. or when im in a low gear going up a hill and keep the throttle at the same position.
Old Sep 16, 2009 | 08:05 PM
scottnfwi's Avatar
scottnfwi
funny thing i just found my trans cable was not connected. after reading alot about tranny shifting problems got me to looking and it was disconnected. but after re hooking it back up it didnt want to shift. but with it off it shifts fine with 2nd to 3rd
being a little long. what gives.
Old Sep 17, 2009 | 12:46 AM
jasonw's Avatar
jasonw
Site Moderator
By transmission cable, are you referring to the transmission cable on the passenger side of the throttle body?
If so, if that isn't hooked up properly (the length adjusted properly), you will have shifting problems. You can't just hook it up and expect it to work, unfortunately.
Old Sep 17, 2009 | 01:12 AM
wjxavier's Avatar
wjxavier
theres a trans cable on the passenger side of the throttle body? :O where exactly? whats it look like?
Old Sep 17, 2009 | 01:29 AM
jasonw's Avatar
jasonw
Site Moderator
Its called the "throttle valve cable", or "TV cable" for short.
Pages 1888-1890 in the Service Manual.
Old Sep 17, 2009 | 07:24 AM
zman17's Avatar
zman17
Retired Moderator - RIP
If it still doesn't shift properly after the TV is reinstalled and adjusted right, then there is a good chance the output speed sensor is no good or has a broken wire/connection etc....
