My truck wont run right
Old Sep 2, 2009 | 11:17 PM
oakleytw's Avatar
oakleytw
Default My truck wont run right
1997 5.2 2wd ram
my truck wont run right! when i start it runs horrible for a few minutes, then it runs great until i drive about 10-12 miles. It starts to back fire a lil and i have to keep the rpms over 3000 or it just stops excelerating. its really hard to get it home once this starts. any ideas??
Old Sep 2, 2009 | 11:20 PM
speeddemon31176's Avatar
speeddemon31176
Test your catalytic convertor by removing the front o2 sensor before the cat and see if it improves the drivability of your truck. When you unscrew the sensor leave it plugged in and hang it up out of the way of moving parts. If this makes it drive better you cat is plugged and needs to be replaced. You can go oem or you can go cheaper depending on whether or not you live in cali and get a high flow cat for much cheaper.
Old Sep 2, 2009 | 11:30 PM
oakleytw's Avatar
oakleytw
I have had the co2 code come up on one of my test drives. my cat has been hollowed out for about three years now and ive never had a problem before..
Old Sep 2, 2009 | 11:50 PM
Twisted Metal's Avatar
Twisted Metal
Have you tested/replaced the o2 sensors? With a hollowed out cat, can't be sure what it is or isn't reading.
Old Sep 2, 2009 | 11:51 PM
speeddemon31176
Ok now that we have that info. I would suggest you pick up a haynes/chiltons/factory manual and a multimeter and test your coil and crank positioning sensor. If your o2 sensor is coming up in a code check replace it. some of the other guys on here have had the o2 sensor be the heart of their drivability issues.
Old Sep 2, 2009 | 11:58 PM
oakleytw's Avatar
oakleytw
how do i test o2 sensors?
Old Sep 3, 2009 | 12:11 AM
oakleytw's Avatar
oakleytw
thank you!!
Old Sep 3, 2009 | 12:12 AM
dakotas ram's Avatar
dakotas ram
did you get ALL of the ceramic out? could be a small bit that keeps getting jammed in the outlet
Old Sep 3, 2009 | 01:15 AM
oakleytw's Avatar
oakleytw
yah its all out
Old Sep 3, 2009 | 01:30 AM
Laramie1997's Avatar
Laramie1997
Probably a fouled up O2 sensor. Have you ever ventured to check the plenum and see if it's leaking? If so, I would bet that it is leaking and that's what fouled the plug up.
