Whats up with these on ebay?
Old Mar 30, 2005 | 07:39 PM
casper's Avatar
casper
Default RE: Whats up with these on ebay?
Those would be the same, but the best one to get is either a ram air or CAI setup. those are just hot air intakes.
Old Mar 30, 2005 | 09:43 PM
nmason's Avatar
nmason
what if i was to use a longer pipe and enclose the filter is a heat shielding box?
Old Mar 30, 2005 | 10:22 PM
mxmancr250's Avatar
mxmancr250
Today when I was putting on my TB spacer I noticed that the back mounting tabs on the air box were broken off and the airbox wasn't sealing all the way so I purchased this kit... http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT off of ebay. It was 115 shipped but it had the K&N filter. I was at an auto parts store today and they were selling K&N filters for 60 bux so another 55 for the piping and mounting isn't too bad.
Old Mar 31, 2005 | 01:06 AM
bign1976's Avatar
bign1976
**** I broke those tabs the first time I changed the air filer
Old Mar 31, 2005 | 01:21 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
As long as you draw in air from outside the engine compartment, you'll have a true CAI effect. The "heat shields" I've seen aren't worth the money...
Old Mar 31, 2005 | 05:56 AM
casper's Avatar
casper
ORIGINAL: dustyloins
Exactly
Old Apr 2, 2005 | 01:02 AM
nmason's Avatar
nmason
im not talking about some premade heat shield. i was picturing the pipe being like 4 feet up to the front behind the passenger headlight. and then making a shirld around the filter.
Old Apr 2, 2005 | 11:49 AM
bigbaddad's Avatar
bigbaddad
So what I gather is it is only good if it is cold air. What brand does everyone suggest and where to get it.On my 99 ram 1500 I have done the exhaust, I what to do air in take and the a chip next. What do all of you suggest. What does any one know about the hyper tech or jet chip. I have seen cheeper ones on ebay. I am concerened about messing with my computer
but I want the mods. to work together. thanks for any imput.
Old Apr 6, 2005 | 11:12 PM
cnewt15's Avatar
cnewt15
I bought one of those. It is a P O S. It wont fit under the cowl. too tall, not to mention the rod that goes through it, wont fit, it is too tall. Dont bother with it guys.
Old Apr 7, 2005 | 03:14 AM
cnewt15's Avatar
cnewt15
ok, i just fiddled with mine a bit, i had to move the hole in the center forward 7/8 inch, then get my own threaded rod, and it worked. It sticks straight out to the pass. side. I plan own adding a bend in it to move it own out towards the pass. headlamp to get cooler air, any more ideas?
