98 1500 4x4 rotor and brake help
Old Sep 7, 2009 | 05:14 PM
Junie's Avatar
Junie
Default 98 1500 4x4 rotor and brake help
Hello everybody and thank you in advance for any help or advice. I have a 98 dodge 4x4 and was going to change the front rotors and pads, I have looked at a couple videos on how to do this and it does not look to complicated. I have not found a specific video for my truck. Can anybody help or steer me in the right direction or any problems I may run into. I need to save some money and I'm pretty handy ( enough to be dangerous ) and would love any help I can get.
Thank you again and will post when I am done to help anybody else.
Lowell
Old Sep 7, 2009 | 05:43 PM
97black_ram's Avatar
97black_ram
Welcome to Dodge forum. There is a lot of information on here covered many times. There's also a DIY Sticky to check out. I would make good use of the search tool.
Here's a link I found by googling your issue.
http://www.ehow.com/how_4894535_remo...dodge-ram.html
Old Sep 7, 2009 | 08:16 PM
99DRAM31887's Avatar
99DRAM31887
+1 to searching the DIY links and welcome to the forum. It's not hard at all just make sure you clean your caliper and re-lube the bushings that the mounting bolts go into helps it last longer.
Old Sep 7, 2009 | 08:31 PM
dhvaughan's Avatar
dhvaughan
welcome to df. 1500 is easy. 2500 can be a bitch.
download and keep this 2001 service manual.
99% of it applies to your 98
http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
