Doing some research on my 1998 Ram Sport
Subscribe
Sep 15, 2009 | 04:47 PM
  #21
Quote: ok, as for the link to the head lights... i am almost 100% srue, the sport model has the same head lights,,,
'99-up Sport headlights are not the same. They are quad headlights with 2 separate bulbs on each side and 2 separate compartments in each housing.
Reply 0
Sep 15, 2009 | 11:53 PM
  #22
Yea I was looking at some of those lights and they have two bulbs and two connectors. Sad part is that when I was looking at my headlights I only have one bulb and one connector. So any ideas where to go now? I then found tucked under the headlight bulb an unplugged connector. No Idea what it goes to. I'm assuming for the headlights but its not connected so I dunno what it goes to. I'll try to get a pic of it and see what you guys think. Also for the last week I have had an interesting error on my dash. I have the ABS and BRAKE light on. I searched the forum here and someone suggested the rear abs sensor was bad. So I changed it with no luck. Any other I deas on what the problem may be? Hope it isn't too serious.
Reply 0
Sep 16, 2009 | 12:57 AM
  #23
most all of the halo projector lights have two bulbs one for high and one for low but only one plug for the headlights..... mine just came incorrectly wired for the 9007 style bulb and I had to wewire for the nonsport 9004 bulb but it was easy enough to swap the two wires...
Reply 0
Sep 16, 2009 | 05:07 AM
  #24
abs and brake with no drivability issues is normally the rear wheel speed sensor. it is on top of the rear differential. if it is not that then it should be the speed sensor on the side of the transmission.
you're lucky to be one of the ones with stock 3.92 gears, i'll get a set some day...
Reply 0
Sep 16, 2009 | 06:32 AM
  #25
i had the same thing, brake and abs lihgt. turned otu to be a rear wheel cylinder. had blown out. so it triped both lights...
as for the lights. i did not know that about the 99 and up lights.. so thank you, but mine is a 98, and as you can see. i have two sectors... two lights, and two halo rings... and they both light up.. and the marker of coarse but yea.. give me an email
Reply 0
Sep 16, 2009 | 11:46 AM
  #26
Just sent you an e-mail mopar. I already replaced the rear sensor and still i get the light but not all the time. So you guys think its the speed sensor or the wheel cylinder? Would I get a code on a scanner to narrow it down?
Reply 0
Sep 16, 2009 | 12:52 PM
  #27
you may come up with a code.. doesnt hurt anything to try it, just go to autozone, and they do it for free.. and it will give you a code...
Reply 0
Sep 16, 2009 | 02:15 PM
  #28
Ok I might try that. Also What on earth is this connector? I found it tucked behind my passenger side headlight. Couldn't find one on the drivers side but I didn't feel like taking the battery out to really hunt it down.
Reply 0
Sep 16, 2009 | 04:10 PM
  #29
Mine has that same mysterious connector. No one seems to know what it goes to.
Reply 0
Sep 16, 2009 | 09:58 PM
  #30
hmmmmmmmmmmmmmm. very interesting. Does it have any power supplied to it?
Reply 0
