99 ram stalling
Old Sep 8, 2009 | 08:14 PM
99ramjrbo's Avatar
99ramjrbo
Default 99 ram stalling
I have a 99 ram 1500 sport, my first dodge. When i stop at lights or the truck idles it wants to stall. Some times i will have to keep one foot on the brake the other on the gas to keep it from stalling. Any ideas or suggestions would be appreciated?
Old Sep 8, 2009 | 08:25 PM
Ram15002ndGen's Avatar
Ram15002ndGen
TPS sensor (Throttle positioning sensor). On the side of the throttle body. Probably bad, needs replacing.
Old Sep 8, 2009 | 08:31 PM
wjxavier's Avatar
wjxavier
either that...or maybe you have a bad front o2 sensor. everytime i would come to a stop, my truck would want to stall and i had to keep my foot on the gas to keep it running. it was a bad o2 sensor. plus, if his tps was bad, him gassing it to keep it running wouldn't do anything i would imagine.
Old Sep 9, 2009 | 11:27 AM
greenmachine's Avatar
greenmachine
Is it hard to start? A bad AIC will have the same type of symtoms.
Old Sep 10, 2009 | 08:46 AM
99ramjrbo's Avatar
99ramjrbo
truck starts fine, i have never had a problem with it starting. It is weird though, the truck sits on my days off, then when i drive it after about 2 days of rest it will run fine the first day. Then it seems like the more i drive it the worse it gets with wanting to stall.
Old Sep 12, 2009 | 12:26 AM
jbomb's Avatar
jbomb
yeah chime in guys I am having a similar problem and didnt want to start another post(I have a new tps sensor and front o2 sensor. Rear is not connected just unplugged untill I get my fastman and I still am using the stock map sensor)
Old Sep 12, 2009 | 11:07 AM
wjxavier's Avatar
wjxavier
if you've already replaced your tps sensor and your o2 sensor, try the IAC(Idle Air Control Valve). kinda self explanitory lol
Old Sep 13, 2009 | 05:23 PM
jbomb's Avatar
jbomb
thanks now I just need to find it. Also I am getting a 140 code (guessing 14 ) from my sct. I am using a used map sensor. but if the voltege is to low or too high then I will have to trace it back to the pcm.
Old Sep 13, 2009 | 05:29 PM
speeddemon31176's Avatar
speeddemon31176
Test both your TPS and IAC with a multi meter and use a manual to verify functionality of both items first. I am unfamiliar with that code due to your using the SCT. If voltage is too high/low on one of those sensors then it is faulty and need to be replaced.
Old Sep 14, 2009 | 03:58 PM
jbomb's Avatar
jbomb
Have a new tps sensor. Need to check my map sensor. But I had a IAC off of a 318 and a 360 and the length of the plungers is about .100 difference.
