Alternator ID Question
Old Sep 9, 2009 | 06:33 PM
eyebrowski's Avatar
eyebrowski
Default Alternator ID Question
It looks like these trucks came with a 117 amp or a 136 amp alternator. How can I tell the difference between the two when picking one from a junk yard?
Old Sep 10, 2009 | 01:20 AM
dakotas ram's Avatar
dakotas ram
download the service manual in the merry christmas thread and it gives you all of the part #s
Old Sep 10, 2009 | 01:22 AM
dakotas ram
https://dodgeforum.com/forum/2nd-gen...tmas-guys.html
Old Sep 10, 2009 | 01:33 AM
J415's Avatar
J415
you can also ask for a build sheet from Chrysler.
Old Sep 10, 2009 | 02:07 AM
pavement_hater's Avatar
pavement_hater
I can tell you that the stud on the back of the alternator where the wire attaches is larger in diameter on the 136a alternator. I upgraded alternators and had to change the end on the wire to one with a larger opening.
Old Sep 10, 2009 | 07:26 AM
aim4squirrels's Avatar
aim4squirrels
you also need to be aware that some years had a 6 rib pulley while others had a 7 rib.
Old Sep 10, 2009 | 11:57 AM
BlueBeast2's Avatar
BlueBeast2
If one had a 117 stock would upgrading to the 136 be worth it?
If one had a 136 stock what's a good one to upgrade to?
I'm pondering beings mine looks like crap buying a new one.
Old Sep 10, 2009 | 12:08 PM
dakotas ram
yes it would be worth upgrading.....if you have the 136 either you can get it rewound or there are some aftermarket ones i believe
Old Sep 10, 2009 | 12:10 PM
BlueBeast2's Avatar
BlueBeast2
I wish I knew where around me I could take it. I would do a deal like indy did and have them take it apart. I'd paint it then they could put it back together
Old Sep 10, 2009 | 02:42 PM
pavement_hater
For me the choice was easy. I needed a new one and the 136a was only $20 more.
