remote start
I finally hook up the remote start but the problem is it starts for about 7 seconds and then shuts off then it will start again for 7 seconds and stops and so on
anybody have a clue what could be wrong......
thanks
Mike
thanks
Mike
Had the same issue with my Hornet and never figured out the problem so I ripped mine back out. Mine would work fine cold, but wouldnt remote start after the truck was warm and would display the same issue your having. There is a tach sense mode which you might have to look into but even that didn't work for me. Give us some more information about your truck and remote start you are working with.
What brand is the unit? If it is made by DEI which is the parent company of Viper, Hornet, etc.. then there is a green wire for tach sense. If you hook that up to your negative side of your coil and program the system for tach sense it will stop that problem. It sounds like it is in voltage sense mode and if it sees a certain voltage it will shut off the remote start. it has to be above 16 volts I believe so if you have a high output alternator it won't work in voltage sense mode. It is a safety mechanism.
What brand?
Mine was doing that and I just had to reset the module. Then it worked fine. You could also have a misconnected wire. It is cranking but isn't getting the run signal to stop cranking and stay running. It's cranking and killing it.
Glad to hear you got it working. I have that sub-brand of starters on my work van and my last vehicle and a brand new one in the box right now to go in the truck here shortly. I have had them installed for over a year with no problems so far. Anyway good luck with your new starter.
