Cylinders 3 & 5 Misfiring! Help
Old Sep 12, 2009 | 10:04 PM
bigslick050's Avatar
bigslick050
Yes I cleared all 3 codes and the check engine light has not come back on.
Old Sep 13, 2009 | 12:55 AM
crazzywolfie's Avatar
crazzywolfie
Originally Posted by bigslick050
Also forgot to add, when I changed the wires, I removed the air filter housing to get to the distributor. The rubber ring that goes to the bottom or the housing to create the seal was dryrotted so I removed it continued to install air filter housing w/out that piece. Is that the cause of my trouble codes? A vaccum leak?
that should not be causing the problem. you could run your truck without it.
Old Sep 13, 2009 | 01:23 AM
Hahns5.2's Avatar
Hahns5.2
Put the old plugs back in and see what happens...
Old Sep 13, 2009 | 04:59 AM
onegoodmason's Avatar
onegoodmason
X whatever it is now , change the plugs , it's that obvious from what you said . I've had a couple of new plugs that were bad before . I run NGK FR4's on the stock 5.2 and FR5's on the modded 5.2 , great spark plugs for mopars . Very fast starts . Typically , I'd say stay stock until you've modded something , but these NGK's do make a difference , and no , I didn't replace old plugs , the "old" plugs were dealer champions only a few months old but I wanted a colder plug to run with the MSD .
Not a big fan of fancy expensive spark plugs , over the yrs I have tried a few , such as split fires and others , pretty sure they are discontinued , with good reason . If it ain't broke , don't fix it , spark plug design should fall into this catagory
Old Sep 13, 2009 | 03:01 PM
bigslick050
Default The final Verdict...
Wow, stupid E3 spark plugs! 60 bucks down the crapper... I bought new Champion plugs and popped them in and she runs flawlessly! I finally got my truck back to normal. I DO NOT RECOMMEND E3 plugs they were junk.
Old Sep 13, 2009 | 03:17 PM
dodgerules86's Avatar
dodgerules86
I've seen countless times on this forum, people say to stick with regular plugs.
Champion and Autolites seem to do pretty good in Dodge motors.
Old Sep 13, 2009 | 03:53 PM
97black_ram's Avatar
97black_ram
Take those plugs back to the parts store and get a refund.
Old Sep 13, 2009 | 04:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe the E3's are just more sensitive to the blown plenum gasket you probably have,
Old Sep 13, 2009 | 07:14 PM
crazzywolfie
i always get those v-grove sparkplug. they are always cheap $20 for all 8.
Old Sep 14, 2009 | 12:42 AM
bigslick050
Smile
Yeah, I think I'll will be sticking with the champs! Now if I could find the receipt to the E3's... Thx for all the helpful info guys!
