truck shuts off when put into ANY gear?
Old Sep 13, 2009 | 06:10 PM
crommie19's Avatar
crommie19
Exclamation truck shuts off when put into ANY gear?
The truck was driving perfectly fine, went to park and pulled in crooked. backed up and went to pull foreword to straighten out and the truck shut off. Now everytime the truck is put into ANY gear it shuts off. it will work in reverse shortly but will rev up to around 2000 rpms i believe when put into 1st, 2nd, 3rd or drive and then shut off.
and ideas would be greatly appreciated. we need this truck up and running as soon as possible as we have a ranch and need to haul more hay.
thank you very much.
it is a 2000 dodge ram turbo diesel 3500.
Old Sep 13, 2009 | 08:41 PM
dhvaughan's Avatar
dhvaughan
edit - oh ****, i just saw it was a diesel. i don't know anything about diesel...
are you saying it revs up to 2000 rpm all by itself.
sounds like a faulty throttle position sensor TPS, on drivers side of throttle body.
or maybe fouled up thottle linkage...
do you have a check engine light ?
does the rpm surge up and down 1000-2000 ?
might be IAC, but i'd guess tps first. about $40 at any local parts store.
Old Sep 13, 2009 | 09:00 PM
pcfixerpro's Avatar
pcfixerpro
Check that trans fluid to make sure its not the torque converter starving for fluid.
