2WD RAM gets really bad mileage
Old Nov 2, 2009 | 05:49 PM
AlabamaRam95's Avatar
AlabamaRam95
id say buy another truck.
notice..."another" not a replacement.
Old Nov 2, 2009 | 06:16 PM
meanwhitemopar's Avatar
meanwhitemopar
well,, around town, my truck when it was stock, got ****ty azz milage, but around highway i had about 15... these trucks are not gas sipping yotas, if you can aford it, get a new one, if not, just check inside the intake for oil, and you will probably notice the oil build up, thats your plenum, change that, and your good, yourtll get alot better milage, as long as you dont do 0-60 checks every stop light...
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by lastrights
look down throttle body for oil
+1, plenum is blown, pre-cat o2 sensor is bad because of it, and the catalytic converter is probably shot because of the plenum too!
Old Nov 2, 2009 | 06:47 PM
Eddielx's Avatar
Eddielx
I have the same problem I last got 280miles on 30gallons..I will look into getting a new cat and o2.
Is that o2 the upstream?
Old Nov 2, 2009 | 06:57 PM
zman17's Avatar
zman17
Yeah, that's the pre-cat sensor.
Old Nov 2, 2009 | 06:58 PM
95RAM360's Avatar
95RAM360
yes just before the cat.
thanks for the info Z, i never thought of the oil gettin guncked up in the CAT. i think im gunna hollow it out...or go to summit and get the high flow
Old Nov 3, 2009 | 10:29 AM
Sheriff420's Avatar
Sheriff420
yep.
a 98 2wd should average (city/highway) about 14-16mpg if you drive sensibly (not stomping on it all the time).
if you don't get one of these http://www.hughesengines.com/Index/p...4&partid=22220 then your plenum gasket will blow out again. probably in less than 50-60k miles.
Old Nov 3, 2009 | 12:20 PM
95MaroonMonster's Avatar
95MaroonMonster
+1 on plenum, my mileage sucks b/c of that
and the fact that i'm driving a truck with a Magnum, and have a heavy foot
Old Nov 3, 2009 | 12:36 PM
95RAM360's Avatar
95RAM360
exacally, it will save you money in the long run. ive noticed way better performance with mine
