Ideas on cams??
Old Sep 17, 2009 | 01:34 PM
postie1686's Avatar
postie1686
Default Ideas on cams??
well guys my ram has started clicking/ticking. weve decided that ive got a couple bad lifters. and seems as ill have to take the top end off. i thought why not go one step more and put a cam in it. i was wondering if any one has done this and what a safe size to put in will be. i guess what is the computer able to compinsat for? i was thinking a 20-745-9 comp cam 264/270 duration with.480/.480 lift?? any ideas or help would be great.
Old Sep 17, 2009 | 01:56 PM
sanford35_5.9's Avatar
sanford35_5.9
I would go with one of the Mopar Performance Purple Shaft cam and lifter sets. I put one in my truck and really like the perfomance gain I got from it, plus the way it runs sound good to. Adv. Duration is 272/278, lift .467/.482, it is rated at +10 hp over R/T. I would change the rockers and push rods also when you do this.
Old Sep 17, 2009 | 02:25 PM
palerider9999's Avatar
palerider9999
Sanford was your 5.9 stock when you made the cam switch? Also what gears are you guys running? That and tire size makes a big difference on cam selection. I want to do a swap and need a proven cam with my gear ratio-3.92's.
Old Sep 17, 2009 | 02:33 PM
postie1686's Avatar
postie1686
right now i have 3.55 gear with 35 inch tires. i know no low end haha. but i have a full set of 4.10's sitting at my house waiting to go in. just this lifter problem happened first
Old Sep 17, 2009 | 02:40 PM
postie1686's Avatar
postie1686
i dont see a cam from them with those specs
Old Sep 18, 2009 | 08:09 AM
sanford35_5.9
My engine was stock when I put the cam in, but when I put the cam in I also put an single plane intake from mopar performance, and a set of shorty headers. Here is the cam part number I put in my truck #P5007551, that number may be different now but about a year ago or so it was right. As far as gears I am running a 4.10 and when I had 33's on my truck I thought I had plenty of power on the low end.
Old Sep 18, 2009 | 11:47 AM
dodgeram07's Avatar
dodgeram07
