Problem with the wheel Bearing
Old Sep 19, 2009 | 05:09 AM
SaddayinCali's Avatar
SaddayinCali
Default Problem with the wheel Bearing
Hi everyone
I have a 2001 Dodge Ram 1500 truck.. and a month ago..we saw the front left
wheel real wabally and felt like the tire was going to fall off.. well the wheel
bearing was shot. So we replaced it..greased it well and thought job well
done. Well Today...same thing..but this time we heard a POP and now the
bearings inside are in pieces. What could be causing this..the Auto parts
say there is no warranty.. So we had to buy a new one at $120 again.
Has this happen to anyone else?
Thanks for your help.. .
Old Sep 19, 2009 | 06:05 AM
Sheriff420's Avatar
Sheriff420
2 wheel drive or 4? big difference in diagnosis between the two.
Old Sep 19, 2009 | 06:54 AM
zman17's Avatar
zman17
Retired Moderator - RIP
I'm going to assume it's 2wd, since the 4wd bearing is non greaseable.
Sounds like either the bearings were not packed correctly, the races were not replaced also or the nut was not adjusted properly(which is what I think is the case). Even on a 4wd the torque of the nut is important. Get a Haynes manual.
And fill out your sig or profile with all the info about your truck! Some one really needs to make this required info during the registration process.
Old Sep 19, 2009 | 09:44 AM
dhvaughan's Avatar
dhvaughan
on the late models like the 01, i thought even the 2wd was non-greasable, thus the $110-120 price tag.
anyway, make sure its torqued right, whatever that is - either finger tight on tradition 2 piece bearings or super-duper tight on those that require it, incl 4wd. its not common for bearings to pop on either 2wd or 4wd unless its got huge tires sticking way out with improper backspacing. and even those usually last a year.
welcome to df. fill out your signature. i'll say it nicer that zman who's always grumpy in the morning.
Old Sep 19, 2009 | 09:52 AM
Sheriff420's Avatar
Sheriff420
haynes says the 2wd hub nut is 185 ft-lbs on 2000 and later.
it also says that its a sealed hub on 2000 and later hubs.
Old Sep 19, 2009 | 10:52 AM
dakotas ram's Avatar
dakotas ram
sounds like it may have been so bad the 1st time that it messed up your spindle
Old Sep 19, 2009 | 07:02 PM
zman17's Avatar
zman17
I've seen and worked on 2000's and up with both types of bearing's(Dodge cheapness or whatever). Although I agree with DV about the price tag, the statement that the bearing was greased is throwing a wrench into the mix. And if it was, some thing is not right, and there is the problem.
And I'm only grumpy when I have to guess and there is *******ly no info about the truck. I normally don't post a reply when that condition is not met. Why waste time typing?
Old Sep 20, 2009 | 01:06 AM
hondarider's Avatar
hondarider
Maybe you just got another bad wheel bearing.. Ive had that happen
Old Sep 20, 2009 | 03:59 PM
SaddayinCali
Thank you all for your post...I will put as much information as I can on the truck right after this post.
It's a 2wd and we figured out that it was the nut that was loose and
cause it to not hold the wheel bearing assembly into place. I drove around
all over to get one. As for whatever reason the auto parts do not carry
them and always have to special order it. and your right dhvaughan
this one is non-greasable.
I will drive it around for a week and check it again..to make sure this does
not happen again, I use the truck on the freeway and the last thing I need
to for my front tire to fall off going at 65mph.
Thank you all for you help..
Old Sep 20, 2009 | 05:57 PM
dhvaughan's Avatar
dhvaughan
Originally Posted by SaddayinCali
the last thing I need to for my front tire to fall off going at 65mph..
that's an understatement.
that big nut might be a dealer only item. they usually have either a cotter pin or crush dimple to prevent them from backing off. i like the crush dimples better as it seems like i can never get the damn cotter slot to line up.
