Problem with the wheel Bearing
Old Sep 20, 2009 | 08:39 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by zman17
or the nut was not adjusted properly(which is what i think is the case).
hmm! ......
Old Sep 21, 2009 | 03:20 AM
SaddayinCali's Avatar
SaddayinCali
You made me think..your right..I should order the part from the dealer to be
safe.. this was close to the original one but was not it..and I have seen the
cotter pin but my truck did not have that.
So...I better get on it tomorrow..I'm not about to loose my life over this..
as it is California LA traffic is dangerous enough..I don't need to add to the
possibilities..
Thanks..A lot for the tip.
Old Sep 21, 2009 | 09:56 PM
dhvaughan's Avatar
dhvaughan
i don't know if yours has a cotter pin or a dimple. but make sure you lock it on one way or the other.
do you know what i'm talking about on the crush dimple? its where the shaft has a slot, and the nut has a steel ring out on the inner edge. after you've torqued the **** out of it, you use a punch to bend the ring into the shaft slot. it locks the nut onto the shaft so it can't back off.
compare the side you're working on to the other side.
Old Sep 21, 2009 | 11:48 PM
hondarider's Avatar
hondarider
I searched all over for the nut and no autoparts store had it. Said its a dealer only..
