overheating problem
Old Sep 19, 2009 | 07:14 PM
DODGEPWR's Avatar
DODGEPWR
Originally Posted by c.mcbee
first off let me say that i am very glad i stumbled onto this site. lots of good info here. ok, to my problem
i checked the thermostat and hwen i saw that one side of it was completely broken off so i figured i had found my problem. i replaced it with a 160* theromstat.fired it up and had the same problem so i got some radiator flush and flushed the rad.did not change anything.
So you say one side of the thermostat was broken off? Did you ever find the other side of the thermostat? Could be causing a flow issue... If its still in the cooling system.
Old Sep 19, 2009 | 07:18 PM
c.mcbee's Avatar
c.mcbee
thanks so muck for the replies guys. when i flushed the rad out a piece of old high temp came out of the drain plug.i replaced the t stat with a new one already but that doesnt mean it is good.i suspect it might be bad because it has the same problems now that it did with the broken t stat.
Old Sep 19, 2009 | 08:23 PM
c.mcbee's Avatar
c.mcbee
when the t stat was boke it was not broke completely off. the top of one side was broke loose preventing it from working. i just pulled the new t stat out of it and boil tested it and it works. so maybe it is the rad?
Old Sep 23, 2009 | 12:01 AM
c.mcbee's Avatar
c.mcbee
back up top
Old Sep 27, 2009 | 07:19 PM
c.mcbee's Avatar
c.mcbee
Old Sep 27, 2009 | 07:51 PM
Twisted Metal's Avatar
Twisted Metal
DVaughn gave you some real good advice in a previous post in this thread. Only thing I would add to his infor would be pressure test the radiator.
Old Sep 27, 2009 | 08:12 PM
dhvaughan's Avatar
dhvaughan
somebody recently posted in another thread that an old freeze plug might have been dropped inside the block or head. that's another potential source of coolant blockage.
Old Sep 27, 2009 | 10:29 PM
EaRSh0T's Avatar
EaRSh0T
mine did about the same thing, would heat up but would cool down if i used the heater. Get a new radiator, picked one up from napa and havent had a problem yet. i think i paid 200 bucks for a radiator and took about 2 hours to do, including the time to go to checker auto for the tranny line tool. SIMPLE
Old Sep 27, 2009 | 11:04 PM
pizzo's Avatar
pizzo
This maybe about the funniest thing to say
get a new radiator cap. with that new radiator if you buy one. I just spend three hours today looking over my neighbors Ram the Fing radiator cap was bad.
the Radiator was leaking so it needed to be replaced anyways. he didn't buy a radiator cap with the new radiator. arrrrr
I found it by luck too had the recovery tank hose off I raised the throttle and see the antifreeze dribble out the overflow
Old Oct 1, 2009 | 08:02 PM
Sawed Up's Avatar
Sawed Up
I noticed my ram leaking a little coolant this evening. The temp gauge always reads slightly over 95, never seen it get higher. As I was looking her over for the source of the leak, while it was running I noticed the upper rad hose is hot, and the lower rad hose is almost cool to the touch. The over flow bottle has been low on water a couple times over the last little while (not in the oil). Seems slightly wet around the water pump casting, but there is an accumulation of dirt there perhaps a slight oil leak, or the seep hole? Pulley seems tight. While the truck is running I can squeeze the upper rad hose and there does not seem to be any resistance at all. I can not feel or hear water rushing by. All leads me to believe the water pump may have given up. What do you think.
