Off Road Factory Parts
I found a 2001 Off Road Ram that was totalled out. Guy said he will sell me both axles the 4 17inch rims tow hooks rear bumper and the suspension for 400 big ones. It should bolt all up under my 98 ram sport i am hoping??? Is there anything i should be worried about at all? Just looking for you guys' imput
well i just talked to the guy again, and it got hit in the drivers fender pretty hard, and there is a chunk out of the rim, so that puts me at 3 rims. going to have to look around for another now. Only thing im worried about is the axle now. regardless i think its still worth it to cut it out. worse case senerio i just take the gears out. my painted bumper is all rusted threw soo the bumper is worth it. I might pull the doors off if they are solid too because my are starting to rot out.
Trending Topics
I have a 2001 off road suspension on my 95 . Nothing to do but bolt things on . The coils were the same height , but the diameter of the coil itself was much larger , to the tune of about 2 inches of height increase , sure stiffened up the ride (not sure I liked the difference ). Not sure , because I didn't swap axles (they got crushed b4 I got back to get them) but I think the frt control arm bolts were bigger than my 95's meaning I would have to drill the frame mount , I looked , it didn't seem to be a big deal if I had to . Something to check out , or expect , maybe 98 is the same
With the list you have and his price , it's a no brainer , jump all over it . Even if by a slight chance either axle is twisted , the 4:10's , if you don't have them , can be switched over at the gear shop
