Low beam Head lights dont work
Old Sep 21, 2009 | 03:01 PM
Fred 46105's Avatar
Fred 46105
Default Low beam Head lights dont work
I have a 2000 ram and the low beam headlights quit working and I cant fin a fuse for just the low beams any ideas?
Old Sep 21, 2009 | 03:24 PM
jasonw's Avatar
jasonw
Site Moderator
There is no fuse or relay for the low beams. There is just a fuse for each individual headlamp (driver side, passenger side).
Most likely the headlight switch is burned up and needs to be replaced. Remove it and see if you can see/smell any burnt wires/plastic on the back. I'd go to a salvage yard, get a replacement, and install it. Cost less than $50. If that doesn't solve the issue, replace the high/low/blinker/etc. multifunction lever with a part from the salvage yard as well, IIRC, the cost for that was less than $50 as well.
