So I'm pulling my motor.
Old Sep 23, 2009 | 10:05 PM
Joey Buentello's Avatar
Joey Buentello
Default So I'm pulling my motor.
What else do I need to remove, I'm down to the flex plate bolts and motor mount bolts. She's ready to pull out, everything is tagged and bagged.
Old Sep 23, 2009 | 10:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Crank pos. sensor, so it doesn't get damaged.
Old Sep 23, 2009 | 10:18 PM
Twisted Metal's Avatar
Twisted Metal
all the fluids drained? Even the water/antifreeze from the block?
Old Sep 23, 2009 | 10:40 PM
Joey Buentello
10-4 on the fluids. Where is the crank position sensor btw?
Old Sep 24, 2009 | 12:37 AM
DODGEPWR's Avatar
DODGEPWR
Behind the passenger head. On top of the trans bellhousing. Two bolts hold it in. Its pushed into a rubber grommet also. So after you get the two bolts out you'll have to pull a little bit to get it out. I think thats pretty much it.
Old Sep 24, 2009 | 10:32 PM
Joey Buentello
10-4 on the sensor.
