Oxygen Sensor High Voltage
Old Sep 24, 2009 | 10:55 AM
UtahLuge's Avatar
UtahLuge
Default Oxygen Sensor High Voltage
So, I already know I need to replace the oxygen sensor but I wanted to get this out here as the manual doesn't mention anything about it.
The manual states the sensor should be jumping from 0.2 to 0.9 volts. Does it do anything strange to the truck or any damage if the voltage is even higher?
Here are my readings:
Pre CAT
Pre Engine Start = 0.02
Start Engine = 1.5x
Engine Running = 0.3x jumping around up to 0.9x
Turn Off Engine = 0.15 slowly dropping to 0.02
Post CAT
Start Engine = 1.5x
Engine Running = 1.4x to 1.5x (never lower)
* I let the engine run for at least two minutes monitoring voltages.
* Post CAT sensor tested first if it makes a difference.
Old Sep 24, 2009 | 11:09 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Testing the voltage is really only testing the heater. The o2 can still be bad even if the heater checks out ok.
Old Sep 24, 2009 | 11:10 AM
UtahLuge's Avatar
UtahLuge
I tested the heater also on the post cat (but not the pre cat as it seems to be ok). It was getting the correct voltage but I didn't get a chance to do the ohm test as the wife was getting upset and wanted me inside to watch the kids.
Edit: The heater isn't really the issue here. Its the high voltage reading the computer is getting back from the sensor. Will that high voltage cause any problems with the computer while I wait for my o2 sensor?
Old Sep 24, 2009 | 11:17 AM
zman17's Avatar
zman17
No problems, just the cel and it won't run as good. But don't wait to replace them once you have them.
