Brake rotors on a 2000 Ram 1500
Old Sep 24, 2009 | 11:56 AM
yellow ram's Avatar
yellow ram
Default Brake rotors on a 2000 Ram 1500
Hey guys. Just purchased a 2000 Ram 1500 and it needs front rotors and pads. I previously had a 99 ram 2500 heavy duty. Is changing rotors on the 1500 as bad a job as it is on the 2500 where you have to pull the spindles apart too? Or do the rotors just slip on and off the front of the spindle?
Old Sep 24, 2009 | 12:02 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Easy as pie, remove calipers, rotors slide right off.
Old Sep 24, 2009 | 12:36 PM
yellow ram's Avatar
yellow ram
Long as they're not rusted on , sounds great. Thanks for the quick response!
Old Sep 25, 2009 | 08:17 PM
seabass202's Avatar
seabass202
use a little never-seize on the hub and inside of the new rotor for good measure. it will ensure next time you need to remove the rotors it will be easy.
Old Sep 26, 2009 | 10:03 AM
Sheriff420's Avatar
Sheriff420
as soon as you take the tire off the rotor will pivot down. i haven't seen one seized to the hub yet. then again, my truck is a southern truck that lives on salt-less roads.
you'll need a 21mm socket to get the caliper bracket off btw. the torque is 130 ft-lbs on the bracket bolts and something like 30 ft-lbs on the caliper bolts.
Old Sep 26, 2009 | 12:37 PM
AlabamaRam95's Avatar
AlabamaRam95
dude....super easy! i did it when i did my leveling kit! and those rotors are dirt cheap!
