4X4 lower balljoint tough to grease
Old Sep 24, 2009 | 10:34 PM
stroken76's Avatar
stroken76
Default 4X4 lower balljoint tough to grease
I have been having a &#%% of a time greasing my lower ball joint. I posted the 90 degree adapter I use anybody have better luck with a different type? Thanks
Old Sep 24, 2009 | 11:26 PM
PurplDodge's Avatar
PurplDodge
I dont think I have ever greased the lower ball joints. I thought the bottom ones were factory sealed anyway.
Old Sep 24, 2009 | 11:40 PM
olyelr's Avatar
olyelr
The last time I replaced mine it seemed to me like there was no room to install a grease cert when the axle shaft went it, thats why they have a low profile screw to put in it once it is greased.
It was always my understanding that to actually grease them the axle shaft had to be removed.
Old Sep 25, 2009 | 08:46 AM
stroken76's Avatar
stroken76
Its a tight fit but I have plug in my axle joint that I can take out and put a fitting in to grease ,then replace the plug. I may try taking some material off the adapter to make it a little thinner to get to the balljoint easier.
Old Sep 25, 2009 | 02:39 PM
helms's Avatar
helms
their are low profile certs made for a needle style grease gun. those will clear the axle and the needle on the gun will reach just about anywhere
Old Sep 25, 2009 | 03:17 PM
stroken76's Avatar
stroken76
Thanks Helms you dont have a picture of one do you? Thanks
Old Sep 25, 2009 | 03:27 PM
stroken76's Avatar
stroken76
I also thought about using something like this but the adapter that goes on the grease gun it too big. found this on ebay http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT There has to be someone out there that has come up with a fix.(Im still looking)
Old Sep 25, 2009 | 04:55 PM
helms's Avatar
helms
http://www.gemplers.com/product/1731...reasing-Needle
http://home.comcast.net/~xterra/tech/GreasePoint.jpg
in the middle of the zerk, there is a spring loaded checkball, its hard to see, but its right in the middle
Old Sep 25, 2009 | 05:36 PM
stroken76's Avatar
stroken76
I know about the needle I have used it for u-joints without grease fittings by going through the seals, I dont think that system would work very well with the preasure required to grease a balljoint. Thanks helms
