4 wheel drive question
Old Sep 25, 2009 | 07:56 PM
dtabj2007's Avatar
dtabj2007
Default 4 wheel drive question
when i shift into 4 wheel drive and give the truck some gas, there is a loud clanking noise coming from the front end. it feel like the truck is in 4x4 but, i can't tell if it's getting power to the front wheels. it makes so much noise like it's slipping out of 4 wheel drive. anyone got a suggestion as to the problem????
Old Sep 25, 2009 | 08:53 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Axle u joints.
Old Sep 25, 2009 | 09:47 PM
wjxavier's Avatar
wjxavier
it is actually probably your transfer case going. time for a rebuild i would imagine.
Old Sep 26, 2009 | 01:02 AM
95MaroonMonster's Avatar
95MaroonMonster
easy way to find out, put it in 4x on dry pavement, mash the gas and replace whatever grenades
Old Sep 26, 2009 | 01:03 AM
townsley4's Avatar
townsley4
lol...i like that solution.
Old Sep 26, 2009 | 01:23 AM
95MaroonMonster
it's fun, until the T-Case locks up at speed...
...thats when the OH SH*T syndrome kicks in
Old Sep 26, 2009 | 09:50 AM
Sheriff420's Avatar
Sheriff420
pull the cad unit and the differential cover off and inspect the gears. if they are not chipped or broken then at least you will have fresh differential fluid.
if the collar in the cad unit isn't broken then you may have a vacuum leak or a bad actuator in the cad that is not sliding the collar over far enough to completely engage the passenger axle.
Old Sep 26, 2009 | 10:48 AM
95MaroonMonster
for the love of god, don't try what i recommended lol
unless you're real pissed and need to relieve stress
