Speedo Problem
Old Sep 30, 2009 | 07:19 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by Sickboy74
Ok guys now I'm lost the local dealer told me my 98 only had the speed sensor in the rear diff now I'm on my third one and still no speedo are you sure I have one on the Tcase because I haven't found it.
98 has 2 speed sensors. one on top of diff (called rear abs sensor) and one in the tail housing of the trans (2wd) or t-case (4wd). rear is about $30, trans is about $16. you can look them up on autozone, rockauto, etc.
Old Sep 30, 2009 | 07:50 AM
greenmachine's Avatar
greenmachine
If you have a handheld scanner you can see if the computer sees a signal. If not then you have a problem with either the computer or the wiring.
