727 Trans shifting to late 97 ram 440 swap any ideas?
Old Sep 27, 2009 | 08:59 PM
celrod's Avatar
celrod
Exclamation 727 Trans shifting to late 97 ram 440 swap any ideas?
Ok i just finished installing a 71 440bb and 71 727 trans into my 97 ram 2wd.
This thing slams 2nd to 1st gear downshift and 1st to 2nd up shift and will not
shift into third with a normal acceleration pattern, but will shift if you gas it and wind it out then let off the gas. I am using the 97 318 46re kickdown cable and i think it might need adjusting but i am not sure witch way to adjust it. does
anyone have an idea about anything else that could be causing this problem
or know where to go to find out
thanks for all the help .
chris
Old Sep 27, 2009 | 09:05 PM
dakotas ram's Avatar
dakotas ram
pics please.....im thinkin that its prob all in your kickdown....how would you even hook our cable up to that?
Old Sep 27, 2009 | 09:10 PM
dakotas ram
wow, i just looked at your pics and that is AWESOME!!!!!!
Old Sep 27, 2009 | 09:14 PM
dakotas ram
youre gonna need sumthin like this or maybe a lokar cable
http://www.aandatrans.com/Products/4...4406B1PWB.aspx
not sure about the 727 but i know 700r4s are very easy to mess up if not adjusted correctly
Old Sep 27, 2009 | 09:15 PM
dakotas ram
http://chucker54.stores.yahoo.net/man727kickit.html
http://www.bigblockdart.com/index.php?topic=39183.0
727 is at the bottom
http://lokar.com/product-description...-kickdowns.htm
Old Sep 27, 2009 | 09:31 PM
Salex007's Avatar
Salex007
off topic but where did you get that hood and front bumper?
Old Sep 27, 2009 | 11:15 PM
celrod's Avatar
celrod
you can get the hood from lmc truck and the front bumper at http://rt1design.com/supertrucks1.html
i will get some pics of my cable set up tomorow after work but the cable is attached to the 727 the same way it is attached to the old 46re with a bracket bolted above the trans pan just behind the shift selector and kickdown lever using the bracket off of the 46re
Old Sep 28, 2009 | 09:43 PM
celrod's Avatar
celrod
adjusted the kickdown cable alot today and got a whole lot better shift pattern but the 1st to 2nd is a little short and the 2nd to third holds a little long but will shift into third without having to work the throttle this trans has a shift kit but i dont know what kind and i have a 4:10 gear in my 9.25 is this shift pattern typical for a shift kit by the way it no longer slams gears at all and i think the kickdown band adjustment maybe out of wack i dont have a torque wrench to set it rite any suggestions
thanks for all the help chris
