Different A/C issue
Old Sep 28, 2009 | 06:11 PM
intense00's Avatar
intense00
Default Different A/C issue-Compressor always runs
Hello all,
great forum you all have here.
it's a great resource for the ram owner.
On my truck the A/C compressor will run on any heater setting except for off.
Just for short term I have pulled the relay, as its getting a lil cold in Chicago.
Anyone know what the problem could be?
Old Sep 28, 2009 | 06:33 PM
halfamil's Avatar
halfamil
Does it blow cold with the temp setting at it's hottest
Old Sep 28, 2009 | 06:54 PM
intense00's Avatar
intense00
No, It does blow warm air, but with the cold A/C mixed in.
Old Sep 28, 2009 | 07:09 PM
halfamil's Avatar
halfamil
No a/c expert here but, sounds like a comp.switch problem.Comp should not engage unless it's on A/C or the defroster mode is on.
Old Sep 28, 2009 | 07:49 PM
95RAM360's Avatar
95RAM360
sounds like your thermostat if you say you can feel cool air when resistor is on hot
Old Sep 28, 2009 | 10:35 PM
intense00's Avatar
intense00
My thermostat is making the a/c compressor run?
Old Sep 29, 2009 | 07:38 PM
DODGEIT105's Avatar
DODGEIT105
I believe that the compressor runs in all positions. It adds dry air to the heat to keep the windows from fogging.
Old Sep 29, 2009 | 09:51 PM
halfamil's Avatar
halfamil
Mine dosen't run in heat mode exept in defrost.
