Cylinder Misfire
Old Apr 2, 2005 | 12:55 AM
cnewt15's Avatar
cnewt15
Default Cylinder Misfire
My check engine light is coming on every couple of weeks or so, then it will turn itself off. When I pull the code, it says there is a cylinder #5 misfire. I hasnt been long at all since i changed the plugs, and even more recently, I replaced the plenum gskt. Does anyone have any ideas?
Old Apr 4, 2005 | 06:44 PM
Badkarma's Avatar
Badkarma
Default RE: Cylinder Misfire
you pulled te number 5 plug and wire? id do that and check the gap and whatnot
