Odd ticking noise. Not engine related
I have noticed an odd ticking noise coming from under my 99 dodge ram 1500.
It sounds as if i have a piece of baling wire stucj on the drive shaft that hits something as as the drive shaft turns. At first i thought is was at the rear now I believe it is at the front. With the windows up I will not hear it, nor will I hear it at higher speeds (wind). I just had new tires put on 2 months ago and the vehilce inspected. I have been trying to figure this out for some time now. Yesterday, i was riding my motorcyle and noticed two other dodges both with the same ticking noise. One was a 2500 the other a 1500--it was an almost identical ticking noise.
It is not the engine--it is clearly realted to vehicle movment.
I do need a new track bar (2nd one) apx 84,000 miles, but I doubt that is it.
Since I have now heard it on other dodges--I thought someone here may be familair with the noise.
TY for any feed back
if your u joints in the drive shaft were lacking grease then it would make a noise like that and you would only hear it in drive at low speed.
take your drive shaft off and move the u joints around to feel for any binding.
