Truck shakes when not accelerating/decelerating
Old Sep 29, 2009 | 02:28 PM
flipture's Avatar
flipture
Default Truck shakes when not accelerating/decelerating
Basically, it won't start shaking for a minute but after you get driving it and get it on the highway or wherever really in about any gear it gets pretty consistent. If I am accelerating or decelerating (basically keeping tension on the drive shaft) everything is fine. Once I begin cruising, the entire truck starts to shake. This is not like a tire balance shake. At that point, if I punch the gas it stops shaking.
My best guess is either drive-shaft carrier bearing or bent/bad drive-shaft. Does anyone know what this might be and if this is a common problem?
Thanks in advance for the help...
Old Sep 29, 2009 | 02:56 PM
charlie1935's Avatar
charlie1935
Check u-joints and carrier bearing if it has one.
95RAM360's Avatar
95RAM360
maybe you need an alignment
Old Sep 29, 2009 | 03:00 PM
AlabamaRam95's Avatar
AlabamaRam95
U joints U joints U joints
Old Sep 29, 2009 | 03:09 PM
flipture's Avatar
flipture
Ok. If it is u-joints would the best bet just be to replace the whole driveshaft?
And I will check if it has a carrier bearing today...
I know it needs an alignment but I don't think that is what is causing the shakes...
Will check.
Old Sep 29, 2009 | 03:30 PM
AlabamaRam95
if its the u joints...just replace the u joints. make sure to get u joints with grease nipples so you can keep the bearings greased.
Old Sep 29, 2009 | 11:13 PM
flipture's Avatar
flipture
Will do thanks!
Any tips on how to check to see if the joints are bad? I'm assuming park on flat ground and leave it in neutral so to there won't be any pressure on the drive shaft then wiggle it and look for play?
Old Sep 29, 2009 | 11:39 PM
charlie1935
Yep. with no strain on driveshaft try shaking and twisting it in every direction you can.
Shoildn't be any slack or play.
If there is play pay attention to the yoke on the rear end and at the tranny end also.
Old Oct 1, 2009 | 10:52 PM
flipture's Avatar
flipture
Was too busy fixing the exhaust leak today (successful) that I didn't have time. I'll check the driveshaft tomorrow...
Old Dec 5, 2010 | 05:23 PM
snowmobilers's Avatar
snowmobilers
Any updates on this? Sounds like the same problem I am having, just had front u joints replaced...
