How long do I make my front arms?
Old Oct 1, 2009 | 05:11 PM
stroken76's Avatar
stroken76
Default How long do I make my front arms?
I want to fab some new arms for my truck, Anyone know the specs. for a 3" lift and 5" lift. Also if anyone has built ther own long-arm set up let me know and post some pics. Thanks
Old Oct 1, 2009 | 05:48 PM
Aubrey's Avatar
Aubrey
The SJ 3" and 5" arms are in the 18 and 19" range. They have an odd number like 18 3/16" or something like that. The uppers and lowers are different lenghts as well. So that'd be your starting point for arms in the stock location.
Old Oct 1, 2009 | 06:47 PM
stroken76's Avatar
stroken76
Thanks Aubrey, I saw something somewhere about 1" added to the upper and lower for a 5". But the more input-expertise the better. Long arms ?
Old Oct 2, 2009 | 10:39 AM
Aubrey's Avatar
Aubrey
That might depend on the manufacturer or maybe you're talking over stock. The upper is actually shorter on the 5" than on the 3" for the SJ. I had the numbers written down somewhere.
I don't know the lenghts on long arms since I don't have them. Fabtech uses a short upper and long lower which I am not a fan of. Most others use long uppers and lowers.
Old Oct 2, 2009 | 01:57 PM
meanwhitemopar's Avatar
meanwhitemopar
just to dd my input.. i have the dick cepek long arm kit.. it was like 600 bucks. but it came with all brakets.. temlets, and everything... they measure a full 48" long.. can be used for anythign from stock to like 10 inchs of lift.. they are great stregth, and flex reall good... ride real nice..
Old Oct 2, 2009 | 08:40 PM
stroken76's Avatar
stroken76
I would think what ever you add to the lower the upper would be close to the same to keep the axle as close to stock angles as possible.
Old Oct 3, 2009 | 02:48 PM
meanwhitemopar
well tht all depends on where you mount the two in conparison to each other.... of coarse.. mine, use new upper mounts on the axle, and the old lowers, but i got new rear mounts of coarse.. and they are a little bit shorter on the top...
Old Oct 3, 2009 | 02:57 PM
meanwhitemopar
[IMG]http://c2.ac-images.myspacecdn.com/images02/16/l_b25fa593cf4245d0870123cc065afcd1.jpg[IMG]
this is with the stock shoks , but if ya look, you can see my long arms, and brakets kinda
Old Oct 3, 2009 | 02:59 PM
meanwhitemopar
Old Oct 3, 2009 | 09:03 PM
stroken76's Avatar
stroken76
If there is anyone out there with a 3" kit with lower arms, and a 5" kit with upper and lower arms could you measure bolt to bolt on your truck and post what you have. Thanks
