Trans problem
Old Oct 5, 2009 | 03:18 PM
gobbell1's Avatar
gobbell1
Did you power wash your truck? Under-neath the chassis? Then you probably got the electrical connectors wet. Our 46RE trannies are electrically controlled.
So...spray a boat-load of WD-40 or similar (water displacement spray) all up and around the tranny electrical connectors. Then report back.
Old Oct 5, 2009 | 04:09 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by 318Ram4x4
i just replaced the speed sensor and checked the wires. that did not fix the problem. i thought it was the govenor pressure solenoid also just didnt change it. i dont know were to order one from and i dont want to go to the dealer and get it.
transmissionparts.com.....both the soleniod and tranducer will run about $100 together....about $50 cheaper than stealership....comes to $202 with % quarts and a good mopar filter from dealership...that were I got mine (I was impatient)
Old Oct 8, 2009 | 04:58 PM
318Ram4x4's Avatar
318Ram4x4
would a governor pressure solenoid from a 46RE trans fit on a 46RH?
