performance upgrade?
Old Oct 3, 2009 | 02:47 AM
jesssed's Avatar
jesssed
Default performance upgrade?
Does anyone know anything about upgraded an 01 ram 3.9L performance wise?
I've see the chip, throttle body, and air-intake. Will these improve gas mileage as well? Is there anything else performance/gas saving wise?
Old Oct 3, 2009 | 03:21 AM
dakotas ram's Avatar
dakotas ram
i would check out the dakota forum....we dont get many 3.9s over here
Old Oct 3, 2009 | 05:09 AM
jasonw's Avatar
jasonw
Site Moderator
The TB and air intake, sure.
The chip.. forget chips. If you can, go with a tuner.
+1 for dakotas_ram's suggestion, I'd check out the Dakotas forums to for some ideas.
Old Oct 3, 2009 | 03:32 PM
dakotas ram
also, they say the v8 tbs work on daks for a little bump
Old Oct 3, 2009 | 04:36 PM
95RAM360's Avatar
95RAM360
throw a 5.9 in it
the 5.9's are easy to upgrade
or if theres a stroker kit for your motor????
Old Oct 3, 2009 | 08:54 PM
lastrights's Avatar
lastrights
3i believe you can install 1.7 harland rockers on the 6 banger
Old Oct 3, 2009 | 10:25 PM
TIMIDONE's Avatar
TIMIDONE
they made rams with 3.9L?
Old Oct 4, 2009 | 12:32 AM
dodgeram07's Avatar
dodgeram07
all most everything a v8 can bolt on
under drive pully...but it will dim the lights till you hit the gas
Old Oct 4, 2009 | 01:18 AM
95MaroonMonster's Avatar
95MaroonMonster
swap in a 5.9 oil burner, same number of slugs, just louder and more funner
