Radiator Changeout - anything peculiar I should know about?
Old Oct 3, 2009 | 07:21 AM
SalBass's Avatar
SalBass
Default Radiator Changeout - anything peculiar I should know about?
My 1997 full-size Ram has 240k on it and I think the leaking radiator needs replacing. It seems pretty straightforward. Is there anything I should know before attempting this? Anything to look out for that's not so straightforward?
The truck has the 5.2L. I believe the radiator has a transmission cooler in it.
How much does an OEM radiator cost? I've seen prices on this interweb for aftermarket units.
Old Oct 3, 2009 | 07:50 AM
aim4squirrels's Avatar
aim4squirrels
I paid $200 at O'Reilly auto for a replacement, but it was definitely thinner material than stock. It actually cooled better though as I think the stocker might have been plugged up in a few passages.
The oil cooler in the radiator for the trans fluid didn't have the same fitting receptors as the OE radiator, I had to buy a couple of brass adapters to make it work.
Old Oct 3, 2009 | 09:16 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Advice? Once you're done, park that truck on a serious incline so that the passenger side is crazy high. It's a bitch to bleed the air out of the Ram setup. I spent the past three years going nuts trying to figure out why my truck kept running hot. I finally go to the point where I parked it nose high, leaning more toward the driver's side. Opened the radiator, fired it up, and let it run. It burped air and finally settled after about 10 minutes at idle and upon reaching 195.
Old Oct 3, 2009 | 11:32 AM
95RAM360's Avatar
95RAM360
when i bled mine, i put 1 jug in, turned it on with heat on full blast then added as it went down, and it went smoothly
Old Oct 3, 2009 | 12:44 PM
DanTheMan44's Avatar
DanTheMan44
I needed a fuel line disconnect tool to seperate the transmission cooler lines, its about $8 at Autozone.
Old Oct 3, 2009 | 03:27 PM
dakotas ram's Avatar
dakotas ram
i bought one off ebay for $109 ahd all right fittings......put about 1/2 qt tranny fluid in when done
Old Oct 4, 2009 | 01:01 AM
Veibz's Avatar
Veibz
$200 at O'reily's! That's crazy. I distribute Radiators in the bristol va/tn area. If you want one man I have lets see.... 216 of them available lol.
$109, figured shipping ...another $6. List price on it is $210.
They make radiators pretty simple these days, if you need the T.O.C. they make them so you can plug right in and be good to go, if you dont need them they self seal.
if I can help shoot me an email. coreyv@eliteautoac.com Good luck man! Make sure you run a good antifreeze mix in the rad...winter can make them freeze over and...crack.
Old Oct 4, 2009 | 04:46 AM
Sheriff420's Avatar
Sheriff420
replace the thermostat while you have it off and make sure you get one that has a bleed hole in it so it will be easier to get the air out of the system.
