Smokes a lot when running?
Old Oct 3, 2009 | 05:25 PM
Mikerecek's Avatar
Mikerecek
Default Smokes a lot when running?
I have a 1994 5.2L dodge 1500 4x4. one day i was just driving down the freeway and all a sudden I stared to lose power. I look behind me and see nothing but a blueish white smoke. the engine dose not knock, it still runs but sounds like it is missing. does any one know or has had a similar problem?
Old Oct 3, 2009 | 06:28 PM
jasonw's Avatar
jasonw
Site Moderator
The blue smoke means you are burning oil, the white might also mean you are burning coolant.
Might be a blown head gasket or cracked head(s).
Do a compression test on the cylinders. They should all be pretty close to one another, within 5 psi or so. Also, watch your coolant level. If it starts dropping after you've driven the truck around, thats a sign that you are burning coolant.
Old Oct 4, 2009 | 08:41 PM
dhvaughan's Avatar
dhvaughan
also check your oil for milky white color. that would be water/coolant.
Old Oct 4, 2009 | 08:54 PM
004x41500's Avatar
004x41500
does your temp gauge read hot? sounds like your plenum gasket is blown... well regardless its a magnum, and their known for their plenum gaskets to blow.
might want to look into the hughes plate, or even the hughes airgap intake, which entirely does away with that gasket.
heres the plate link http://www.hughesengines.com/Index/p...6&partid=22220
heres the airgap link http://www.hughesengines.com/Index/p...=&partid=24773
Old Oct 4, 2009 | 09:06 PM
dhvaughan's Avatar
dhvaughan
i think he has a more serious problem than the plenum.
+1 on compression check.
Old Oct 4, 2009 | 09:17 PM
004x41500's Avatar
004x41500
he stated hes seeing a bluish white smoke, which leads me to believe oil, as ive seen bluish white from burring oil before. but a compression test wont hurt.
+1 on that as well.
Old Oct 12, 2009 | 04:13 AM
Mikerecek's Avatar
Mikerecek
Default Did the compression test all was fine.
Every cylinder is got great compression but one, one cylinder is 9 psi lower than the rest. on start up smokes really bad. when its warm smokes really bad. it does not get hot, water temp stays normal. the oil pressure is good. the oil smells a little like gas. its missing really bad on at least two cylinders. I looked down the intake and I can see oil just sitting at the top of the intake. Where is it coming from?
Old Oct 12, 2009 | 08:17 AM
95RAM360's Avatar
95RAM360
thats a sign of the Plenum gasket
Old Oct 12, 2009 | 08:06 PM
004x41500's Avatar
004x41500
ya look at my previous post 4, and theres really youre only two options to fix the plenum.
Old Oct 12, 2009 | 09:03 PM
dhvaughan's Avatar
dhvaughan
i don't know. the suddenness of the cloud of smoke concerns me. the plenum has probably been leaking a long time and gradually getting worse. the all-of-a-sudden cloud of blue oil smoke makes me wonder about plenum, valve seal, ring, or cracked something. the favorable compression test results seem to rule out the head gasket, and compression rings. maybe its plenum only. i hope so.
is any one spark plug looking worse than the others?
