Hard to start but runs good
Old Oct 3, 2009 | 09:30 PM
bankrobber's Avatar
bankrobber
Default Hard to start but runs good
I have a 1998 with 360 and 4x4 automatic with 180,000 miles.
Has starting issues as I turn key and crank it over few seconds then shut it off and crank again till it starts. Once running it is fine. I have replaced spark plug wires before starting problem. The engine light is not on. Not sure if I have a furl problem or electrical issue. Please help
Old Oct 3, 2009 | 10:47 PM
95RAM360's Avatar
95RAM360
does it crank slow or normal when it does crank over?
Old Oct 3, 2009 | 11:12 PM
bankrobber's Avatar
bankrobber
It cranks normal and has a new battery. It spins over like normal just takes a few times to start. Once running it will idle and drive ok.
Old Oct 4, 2009 | 12:24 AM
Miami_Son's Avatar
Miami_Son
Check your fuel pressure. Could be leaking down when you turn it off.
