Tune up parts
Old Oct 5, 2009 | 03:16 PM
Dr Donut's Avatar
Dr Donut
Default Tune up parts
Getting ready to do a tune up on my truck and i picked out some wires and wanted to know if anyone thought they were good I also need to know what kind of plugs would work best
http://www.summitracing.com/parts/MSD-32183/
http://www.summitracing.com/parts/DCC-4876255AB/
Old Oct 5, 2009 | 04:23 PM
halfamil's Avatar
halfamil
Personally,I would never spend that on those parts,simply because $30-$50 would do the same job.
Old Oct 5, 2009 | 04:45 PM
AlabamaRam95's Avatar
AlabamaRam95
really...spark is spark, but if you feel obligated to spend that kind of money on ignition, then get this.
http://www.performancedistributors.com/dtrkignition.htm
...and use ngk v-power plugs...like $1.89 each and they are perfect.
Old Oct 5, 2009 | 04:50 PM
Sheriff420's Avatar
Sheriff420
why aluminum for the cap instead of brass?
Old Oct 5, 2009 | 08:20 PM
Twisted Metal's Avatar
Twisted Metal
Try this, same setup as I use. Brass inserts in cap and on rotor.
http://www.summitracing.com/parts/SUM-867815CR/
Old Oct 5, 2009 | 08:23 PM
dhvaughan's Avatar
dhvaughan
i just used the lifetime wires at the local parts store for about $39.
i used the autolite 3923 when because i had a pinging problem.. they've been fine and they're cheap.
Old Oct 5, 2009 | 08:24 PM
dodgeram07's Avatar
dodgeram07
+1,twisted
Aluminum= poop
Old Oct 5, 2009 | 10:18 PM
halfamil's Avatar
halfamil
Now that looks more like what I would pay, these engines just don't need more than that.
Old Oct 6, 2009 | 03:29 AM
Dr Donut's Avatar
Dr Donut
I think that ill just go with this because its way cheaper and the general consensus is that it wont make a difference
Old Oct 6, 2009 | 07:51 AM
jasonw's Avatar
jasonw
Site Moderator
Brass usually doesn't corrode like aluminum does, hence why most aftermarket caps are of the brass variety.
