werid noise coming from driver side engine
Old Oct 5, 2009 | 03:18 PM
townsley4's Avatar
townsley4
Default werid noise coming from driver side engine
i just recently replaced my steering gear box, and hoses, and when i started the truck with the hood open, there is this weird sucking fluid sound coming from what sounds like somewhere around the valve covers? a couple of the outside bolts on the valve covers wer loose so i tightened the ones i could get to, but didnt get to the ones on the inside. they wer loose about 1 full turn. but now there is this sound coming from it(louder when its cold). im not sure what it is. has anyone ever had this or any idea what might cause it?
Old Oct 5, 2009 | 08:52 PM
dhvaughan's Avatar
dhvaughan
sounds like the pcv valve, which is in the big rubber o-ring in the valve cover. its sort of a controlled vac leak.
Old Oct 5, 2009 | 10:15 PM
townsley4's Avatar
townsley4
hmmm....yea its kind of an airy sound...sounds like a mixture of a buzzing sound, and suckign fluid sound...but it just recently started doin it.
Old Oct 5, 2009 | 11:06 PM
townsley4's Avatar
townsley4
u think if i pulled it out and cleaned it, it might help? would i be ablet o clean it with wd-40? i dont have carb cleaner here.
Old Oct 6, 2009 | 12:32 AM
Ramman18's Avatar
Ramman18
If it is the pcv just buy a new one. Less than 5 bucks and it's a replacement item. You wouldn't "clean" out an old oil filter would you? Just don't get a Fram pcv.
