1995 Ram Exhaust
Old Oct 6, 2009 | 01:14 PM
mjackson92rs's Avatar
mjackson92rs
Default 1995 Ram Exhaust
Having trouble finding a exhaust for my truck. its a single cab long bed 2500 4x4 with the 5.9 and all i can find is single out the rear. im looking for dual out the rear or dual out the side. any help here?
Old Oct 6, 2009 | 01:19 PM
Augiedoggy's Avatar
Augiedoggy
you must not have searched very hard ebay brought up a couple hundred (they are the same as the 1500 ) and google brought up a ton more
http://lmgtfy.com/?q=2500+ram+dual+exhaust
Old Oct 6, 2009 | 01:21 PM
mjackson92rs
will a 1/2 ton exhaust work on my 3/4 ton? also, does it matter that my truck is a single cab long bed or are all exhaust kits the same on these trucks?
thanks auggie.
Old Oct 6, 2009 | 02:29 PM
dsertdog56's Avatar
dsertdog56
Most of the kits listed require a bit of fab work to install. Unless the kit states its only for a regular cab short bed, theres probably enough "meat" on the pipes to make it work.
On my system (vortex), the wheel base determined the length of the pipe between the converter and muffler. That was the key to making everything work, and I had to trim my tailpipes because they were too long.
I would check the listings by wheel base.
Just checked my JEGS catalog....#555-31120 says it fits all wheelbases 94-01 with 2 1/2 dia catalytic converter. 239.00 plus freight.
Old Oct 6, 2009 | 02:37 PM
Augiedoggy's Avatar
Augiedoggy
thanks auggie.
they are listed as the same....same engine same truck body everything else is the same just beefier so...deisel is the only real exception I believe.
Old Oct 6, 2009 | 03:33 PM
lastrights's Avatar
lastrights
just buy a muffler you want and a highflow cat, and have a shop do a custum exhaust the way you want , best way too do it
Old Oct 6, 2009 | 03:39 PM
Twisted Metal's Avatar
Twisted Metal
+1 For Auggie, an exhaust for a 1500 will bolt right up on a 2500 provided you match the truck specs. I.E. short bed, long bed, ext cab, etc.
