Lug nut wont come off
Old Oct 6, 2009 | 02:31 PM
Relex's Avatar
Relex
Default Lug nut wont come off
I'm trying to get my wheel off to come across one lug nut that was very tight when turning even after the point that it was broken loose. I got it all the way to the end and it just spins.
What do I do from here?
Old Oct 6, 2009 | 02:36 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Replace the stud and or lug nut. Could be cross threaded.
Old Oct 6, 2009 | 02:56 PM
Augiedoggy's Avatar
Augiedoggy
should come out if you pull on it while turning it
Old Oct 6, 2009 | 04:31 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Gee ,you think so? lol
Old Oct 6, 2009 | 04:35 PM
zman17's Avatar
zman17
Obviously you have to replace both anyway, I'd try what Augie said, if that doesn't work, grab the nut with a pair of vise grips and while pulling, wobble the nut up and down. If it's right at the end, the rest of the threads should just shread away.
Old Oct 6, 2009 | 04:55 PM
Relex's Avatar
Relex
Thanks I'll have to try what you guys said. I'll post when the results when I work on it again tomorrow.
Old Oct 6, 2009 | 09:33 PM
dodge15004x45.9
Thanks I know I'm good!
Old Oct 6, 2009 | 10:01 PM
Eddielx's Avatar
Eddielx
You could use a nut splitter.
Old Oct 7, 2009 | 11:30 AM
Sheriff420's Avatar
Sheriff420
i doubt he could get a nut splitter on it due to its location.
i think the best thing would be to pull on the wheel while a helper spins the 4 way so you will be using the rim to keep pressure on it.
Old Oct 7, 2009 | 11:46 AM
AlabamaRam95's Avatar
AlabamaRam95
"if at first you dont succeed... well... get a BIGGER F*****G HAMMER!"
