HID headlights...
Old Oct 7, 2009 | 01:00 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Junk? How do I know the other kit aint junk?
Old Oct 7, 2009 | 01:07 AM
Laramie1997's Avatar
Laramie1997
What you are posting about IS junk. Common sense should tell you to run far far away. For Christ's sake! It's glues together. Jason is speaking from experience here. Not pulling this out of his ***....
Old Oct 7, 2009 | 02:38 AM
[roger]'s Avatar
[roger]
there a place by west rd @ I45
but internet is where i got mine my temp DD taurus
Old Oct 7, 2009 | 11:34 AM
hometheaterman's Avatar
hometheaterman
Originally Posted by jasonw
These are really nicely priced units, and I've heard a lot of good things about them. I plan on using their stuff when I get a little cash here in the next few months.
http://www.ddmtuning.com/index.php?p...=101&parent=85
Keep in mind you may have to rewire your lights, using relays from the battery, to get enough power to start up the HIDs. HIDs, once on, use less power than regular halogen bulbs, but to start them up, they require a little bit more than regular halogens.
I was going to suggest them but he said he didn't want a cheap kit. I've used XenithXenons which cost more and I have been happy with them. I did have a issue on my bike just recently where only sometimes would one bulb come on but he told me to swap the ballasts to make sure it was the ballast. We would know it was if the problem moved to the the other side it would be. Well, after I swapped the ballast to the other sides it hasn't happened yet so maybe it was just a loose connection.
If I was to do it again I'd probably just save the money and get the kit from DDM Tuning. I don't know that there is much difference unless you want to spend the money to go for a high end kit like a Phillips or OEM type kit.
Old Oct 9, 2009 | 09:41 AM
swamp's Avatar
swamp
what kit would u use for the sport headlight since i see most are only two bulbs in the kit and the sport model has two bulbs per side
Old Oct 9, 2009 | 03:58 PM
dodge15004x45.9
There should be a kit as well for the sport. Let me try to find it from jason's link. Ok I looked but could not find it Jason should be able to shed some light.
Old Oct 9, 2009 | 08:06 PM
jasonw's Avatar
jasonw
Site Moderator
You'd have to buy two kits, a 9004 kit and a 9007 kit, since the inner bulbs (closest to grille) are 9004s and the outer bulbs (farthest from grille) are 9007s.
You'll have that problem no matter what HID company you go through, unfortunately, since you have four bulbs. Personally, if you had to choose to do one first (if $$$ is a little tight), I'd do the 9007s first since those are your low beams (used more often). Then when funds permitted, the inner 9004s (highs).
Old Oct 21, 2010 | 11:33 PM
viperziper's Avatar
viperziper
How do we compare ddm scam are they as good as they state. DDM TRUTH?
