What temp is your engine running at?
Old Oct 6, 2009 | 11:22 PM
bardram's Avatar
bardram
Default What temp is your engine running at?
I have only owned my Ram for a few weeks, and I have noticed that the temperature guage is reading about 220 degrees. I have owned many vehicles in my day and the needle is usually dead center but my Ram seems to be past the middle. I just ordered a hypertech 160 degree thermostat, maybe that will help.
Old Oct 6, 2009 | 11:34 PM
Ramman18's Avatar
Ramman18
That is a little hot, as it should read about 200 with the stock 195 stat. Over the years, the research I've done says don't put in a 160 stat as it is too cold. Most of us are running 180 stats.
Old Oct 6, 2009 | 11:44 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Agreed.
Old Oct 6, 2009 | 11:50 PM
Augiedoggy's Avatar
Augiedoggy
mine was around 220 also before installing the 180 stat from pepboys last week...all is good now for me.
Old Oct 7, 2009 | 12:15 AM
Veibz's Avatar
Veibz
Mine has never reached 1/2 way. Normally sits about a needle width below. It has been on C for about 5 hours now. But that will change shortly after I start it
220 is a little too hot, I like the 180 range much better
Old Oct 7, 2009 | 12:41 AM
dodgeram07's Avatar
dodgeram07
mine has never hit 200...with the org 195 t-stat!!!!!!!!
Old Oct 7, 2009 | 12:47 AM
dodge15004x45.9
I have mine up t0 220 + on the beach running 30lbs in 4h doing between 20-40.
Old Oct 7, 2009 | 01:23 AM
roadney's Avatar
roadney
mine was running 230. The fan clutch was bad, replaced it the water pump and thermo with another 195 and now run from 200-215
Old Oct 7, 2009 | 01:30 AM
Laramie1997's Avatar
Laramie1997
with 195 stat- 200-220
With 185 stat- 185-190
Old Oct 7, 2009 | 01:40 AM
dakotas ram's Avatar
dakotas ram
i have been running about the same as you, put in a 180 and no change, new rad, no change, temp sensor was the problem.....with a 160 youll run around 180 probably
