tonight coming home from work my speakers were clicking/popping, i let off the gas and it went away, give it gas and it comes back, what would be the reason for this? i know older vehicles had the little thing that helped with that, does ours? also, how can i improve my radio reception?
I'd come close to thinking you've popped a channel on the amp. You might try turning down the line signal and see if that helps. Could also be that you have a wire in the engine bay that's bare and that's where you are hearing the engine noise.
i drove it again this mornin and i was with my g/f so i had the radio on but turned all the way down and i noticed when i press the brake there is a little static come thru
sounds like your picking up interference from your alternator. Try checking your main power supply line to your amp. I know i had the same problem with my stereo and it was because i bought a cheaper power feed wire, picked up a higher end one and the problem was gone.
