Shock Suggestions Needed
blah blah blah...I am going to do the Diesel/V10 coil spring in front and 2" add-a-leaf in the back this means at least new shocks in the front.
So my philosophy is too just do all four together! I need people's suggestions: brand, cost, and link to it if you got it.
Thanks in advance. Oh and side note I don't need/want the most expensive #*$& out there.
ive heard doetsch tech are a really good shock, a set is around $200......
you can go on their site and shoot them an email and tell them your vehicle info and that youre putting that spring in and it should raise about 3" or whatever and its supposed to be rougher than stock and they will tell you their recommendation and length, same for rear.......i wouldnt go for parts store shocks since you wont be stock height unless you know what part# will give you the length you need.....them douches wouldnt be able to set you up with what you need
http://www.doetsch-shocks.com/
I've 3 different shocks on mine, stock-HD Gabriel-Bilstien.I swear I could not tell the difference in the three of them.
