My Ears Are Bleeding...
Old Oct 11, 2009 | 05:05 PM
Augiedoggy's Avatar
Augiedoggy
Originally Posted by 004x41500
the whine can also come from induced noise in the rca wires,if their ran along side the power wires. one fix would be to buy a set of twisted rcas or just run the rcas down the other side of the truck.
good advice. Any shielded rca cables would help in removing it if this is the cause.... usually the whine is caused by a ground loop or very cheap amp or HU with poornoise filter circutry
If your stereo is grounded to the battery and your amp to the frame this will happen (you want them both grounded to the truck body or chassis)....also remember you want your ground for the amp to be as short as possible...like three feet and ground it to good clean metal free of paint
Old Oct 11, 2009 | 07:40 PM
004x41500's Avatar
004x41500
ya true, though i dont know about the stereo groudn, cause i have my amp grounded through my seat bolt, and the stereo is grounded through the wire harness. and i dont get any whine. but ya, the length of ground wire does make a difference, mines like literally around 18 inches.
heres the link to my post with pics of my setup.
https://dodgeforum.com/forum/1833541-post1622.html
