Jeep guy...what?
Old Oct 14, 2009 | 12:37 AM
Travis873o's Avatar
Travis873o
Default Jeep guy...what?
so I am a member of Jeepforum and came across an applicable motor to you guys. so...
I was in the shop on campus today and came across a motor and transmission that has been sittin in the same spot for 4 years (from what i was told). Looked exactly like the 318 in my Grand Cherokee. However, I saw that it had the starter on the driver side which means its from a Ram (as the starter is on passenger side in Jeeps). I'm hoping it might be a 360 w/ the matching 46RE transmission. Is there any way to tell if it's a 360/318 or a 44RE/46RE?
Old Oct 14, 2009 | 12:54 AM
AlabamaRam95's Avatar
AlabamaRam95
Look on the front of the block just below the driver's side head. There should be a stamped number there which will include the displacement.
Also, most of the 5.2s got the 44re and the 5.9s got the 46re.
Old Oct 14, 2009 | 01:01 AM
dodgeram07's Avatar
dodgeram07
the 5.2 is internally balanced and the 5.9 is not so it will have a balancer on the crank and the 5.2 will not
Old Oct 14, 2009 | 01:10 AM
Travis873o's Avatar
Travis873o
okay, good deal.
anyone know the compatibility of the dodge 360 into a the spot of a jeep's 318?
Old Oct 14, 2009 | 03:24 AM
dakotas ram's Avatar
dakotas ram
pcm change.... and depending on the year that tranny could be rh
Old Oct 14, 2009 | 07:46 PM
Travis873o's Avatar
Travis873o
it's a 44RE. and from what i've heard, i could still use my existing pcm but it wouldnt give me the richer fuel mixture i'd want.
does this sound right?
Old Oct 15, 2009 | 04:02 AM
BRRMudderTrucker's Avatar
BRRMudderTrucker
Well according to the information that I have found the 42RH was used for the V6 2WD, the 46RH was used for the V6 4WD and V8, and the 47RH was used for the V10 and Diesel (1994-1997), 42RE was used for the V6 2WD, the 46RE was used for the V6 4WD and V8, and the 47RE was used for the V10 and Diesel (1998-2001), other years I'm not sure....
